Orbi WiFi 7 RBE973
Reply
Changing Orbi Region
KipiYI
Initiate
Hi,
I have searched for a way to change the region from US to Europe. Here it is:
1) Enable telnet on router and satelite by enabling telnet on web management
 e.g. 192.168.1.x/debug.htm
2) Look at the instructions in this link (orbi has Atheros chip, it explains how to change it to russia, buy you can change to any region, play with the artmtd command, use help if needed):
http://developers-club.com/posts/195058/
Done!!!
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
superczar
Apprentice
Re: Changing Orbi Region
Thanks for the tip.
I was looking for a way to change my region to NA to have at least a reasonable amount of power on the 5ghz band (my backhaul was at 20dbm leading to very poor backhaul speeds even at 20 feet and 1 wall-the satellite would switch over to 2.4ghz )
This is what worked for me:
a) telnet and verify region ->
artmtd -r region
should return current region
b) change region to NA
artmtd -w region NA
verify new region via (a) above
This alone does not change all the region settings, specifically the radio power as validated by "iwlist txpower" which remained the same even after the region change
I subsequently did a 30/30/30 reset followed by a regular reset
After this, I had to re-setup the device
Post this, iwlist txpower showed me the expected power settings
The backhaul is now 500mbps+ and the 5ghz radio range is significantly improved
Message 2 of 3
KipiYI
Initiate
Thanks for the info.
By the way, you can also set it to region free (WW).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 6982 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
