CI34
Mar 27, 2020Aspirant
Using Orbi RBK20W with AT&T BGW210
I just purchased the Orbi RBK20W for my home. I currently have AT&T internet but the speed and signal in my house stinks. I have the BGW210 modem/router. I originally was going to buy a Netgear me...
tomschmidt
Mar 27, 2020Virtuoso
CI34, once you disable the WiFi on your old router, also set it up to passthrough to your Orbi. On the Orbi, set the SSID and its password and security settings like you had on your old router, then all of your devices will reconnect to the Orbi using your SSID.
Example: Old router had SSID "MyWiFi" and SSID password "1234" with WPA2-PSK security.
Once you disable the WiFi on the old router, set the SSID on the Orbi to "MyWiFi" and password to "1234" with WPA2-PSK security. Now your WiFi clients will find the new WiFi network being supplied by the Orbi.
CI34
Thanks so much Tom
- CI34Mar 27, 2020Aspirant
Need some more help. During setup, I changed the network SSID to my old network name and SSID password to my old password. But somehow the Orbi app keeps trying to connect to the original Orbi14 SSID that it came out of the box with. And when I disabled the wifi on my BGW210, we could not reach any websites. Any suggestions? Is there a way to change the Orbi SSID and SSID password back to what it came out of the box with temporarily? I fear I may have changed the name & password too early in the setup process. Thanks.
