jayrg
Dec 27, 2018Follower
Using rbs50 from another package
A friend has offered to give me his rbk50 with 2 satellites. I already have an rbk50 with 1 satellite. Is there any reason I can't use the satellites from the other package with my existing setup? ...
Dec 27, 2018Guru - Experienced User
No reason at all, they are the same 50 series satellites used in the RBK50 series kits. You can hook up additional satllites. You can't use the RBR50 router as a satellite, works only in router or AP mode. No satellite support there.
Enjoy.
Thanks,
Jay
