geoffdm's avatar
geoffdm
Using the Mac Remote Desktop software - Mac to Mac remote management
Hiya,
I have recently purchased the Orbi RBK53 Router with two satalites.
When i connect to the Orbi network i cannot remotely manage my iMac using the Mac software Remote Desktop, when i switch to the default broadband routers wifi it works no problem. What settings do i need to enable/add to the Orbi to enable this to work please?
I think the Remote Desktop uses the following ports on a MAC
Any ideas?
  • FURRYe38's avatar
    What FW is currently loaded?
    How are the Macs connected to the orbi system? Wired or Wireless?
    Where are the Macs connected, to the base router or the satellite, one at the base router and the other at the satellite?
    If there both on the same connection point, there shouldn't be any configurations needed.
    • geoffdm's avatar
      geoffdm
      V2.1.4.16
      Truespeed -no idea of modela s it is whitelabel
      Wireless
      Where are the Macs connected, to the base router or the satellite, one at the base router and the other at the satellite? Both the main orbi router at the moment
      If there both on the same connection point, there shouldn't be any configurations needed. Ok, strange as its not working. Thanks though for comments!
      My Setup (Cable 900Mb/50Mb)CM1000r>XR450> > EX7700 (Wireless Extender)
      Additional NG HW: Orbi CBK40(Gateway Mode), R7800, EX7500/EX7700 and WNHDE111
      • Blanca_O's avatar
        Blanca_O
        NETGEAR Employee Retired
        Hi geoffdm,
        Welcome to NETGEAR Community!
        Have you tried resetting the router and the satellites?
        Blanca
        Community Team
