Charlie97
Jul 12, 2017Aspirant
Using the orbi as a standalone router with fibre optic
I want to be able to just use the orbi router instead of having a modem along side it as a bridge. how would I set it up to just be standalone when my internet is fibre optics? I've done everything it...
- Jul 13, 2017
Routers and a modems do different things in terms of supplying your internet connection.
There are some devices out there that can do both router and modem functions together in one unit, but they aren't very common (long story).
Orbi is not one of those devices... The Orbi system is a routing device exclusively - it requires a seperate modem to be connected to it in order to produce your wifi network....
Internet cable coming into your house -> Modem -> Orbi -> (wifi) -> your various internet toys
Charlie97
Jul 13, 2017Aspirant
Thank you people I get it now
st_shaw
Jul 13, 2017Master
Not so fast... Most fiber to the home services, including Verizon FiOS, do not require a modem at all, and interface using an RJ45 connection to a router. It's possible the OP does not need a modem. Whether he needs one depends on what Internet provider he uses and what equipment is already installed in his home. If he currently has a box that's only a router, then he might be able to replace it with Orbi.
