darkleafar
May 20, 2017Tutor
Uverse + ASUS RT‑AC5300 + Orbi AC3000. Best setup?
Evening ladies and gents! I just purchased an Orbi AC3000, and I am very excited to set it up. I have not though, because I am still trying to figure out the best possibly configuration. First,...
- May 23, 2017
The Orbi setup is quite smart.
It will detect the existence of any other routers and set itself up accordingly with a different IP address range to avoid conflict.
Why don't you try and run it with the Asus in place and see how it performs?
Having said this, I am also a Uverse customer and had the same coverage issues (3700 sq ft) as you so installed a secondary router downstairs as well.
After getting Orbi I replaced the secondary router with the orbi router and placed the orbi satellite upstairs in a central location (The AT&T RG was in a closet behind a panel).
I now have whole house coverage including outside and even when I visit the neighbors!!
DarrenM
May 22, 2017Sr. NETGEAR Moderator
Hello Darkleafar
If you like some of the features on the ASUS then using orbi as a access point would be the best bet. And you could disable the ASUS wifi this will make it so you only see 1 wifi network in your home instead of multiple.
DarrenM
- darkleafarMay 22, 2017Tutor
Thank you for the reply. You don't think it ll cause a problem doing double bridge since im already doing that from uverse to asus?
- Streak2May 23, 2017Master
