In5iDi0uZ
Jul 22, 2019Guide
V2.3.5.30 Broke Bridge Mode Dont Upgrade
Frustrating weekend troubleshooting. I use Orbi RBR50 and a RBS50 also use a R7000 in Bridge mode for my pc, using 5GHz, for last couple years. I had updated the Orbi and the R7000. After this It wo...
SW_
Oct 10, 2019Prodigy
In5iDi0uZ wrote:Well it auto-updated again this morning, and broke the connection again. I downgraded and followed the steps in this link: https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/m-p/1323973/highlight/true#M10304.
I'll just keep applying this whenever the router reboots, if that's what it takes for my connection to work.
The 3 configurations highlighted above you will want to update the value from =1 to =0 orbi_auto_upgrade=1 auto_check_for_upgrade=1 auto_update=1
Just an FYI...
The auto_update flag/setting has nothing to do with Orbi firmware auto update. The auto_update flag controls and affects QoS behaviors. QoS can impact Orbi performance depending on download/upload speed.
In5iDi0uZ
Oct 10, 2019Guide
Just an FYI...
Good to know. Thank you. Do you know what orbi_auto_upg might be?
