In5iDi0uZ
Jul 22, 2019Guide
V2.3.5.30 Broke Bridge Mode Dont Upgrade
Frustrating weekend troubleshooting. I use Orbi RBR50 and a RBS50 also use a R7000 in Bridge mode for my pc, using 5GHz, for last couple years. I had updated the Orbi and the R7000. After this It wo...
SW_
Oct 10, 2019Prodigy
In5iDi0uZ wrote:
SW_ wrote:
In5iDi0uZ wrote:Well it auto-updated again this morning, and broke the connection again. I downgraded and followed the steps in this link: https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/m-p/1323973/highlight/true#M10304.
I'll just keep applying this whenever the router reboots, if that's what it takes for my connection to work.
The 3 configurations highlighted above you will want to update the value from =1 to =0 orbi_auto_upgrade=1 auto_check_for_upgrade=1 auto_update=1
Just an FYI...
The auto_update flag/setting has nothing to do with Orbi firmware auto update. The auto_update flag controls and affects QoS behaviors. QoS can impact Orbi performance depending on download/upload speed.
Good to know. Thank you. Do you know what orbi_auto_upg might be?
What I'm able to find out thus far:
- orbi_auto_upgrade records timestamp
- auto_check_for_upgrade is actually a no-op. Otherwise, new firmware version notification will never show up on firmware update page.
- auto_update controls QoS behaviors.
- orbi_auto_upg is controlled by Enabled/Disable radio switches via the hidden section of the firmware update page.
- orbi_auto_flag doesn't seem to exist and I couldn't find it anywhere in the firmware or its reference. I don't know what it does. Maybe someone knows.
In5iDi0uZ
Oct 11, 2019Guide
WElp
Welp, i must be missing some setting, cause it updated again and lost connection.
- SW_Oct 11, 2019Prodigy
In5iDi0uZ wrote:WElp
If auto-updating kept happening via telnet method, factory reset the Orbi and give the hidden UI method a go?
- In5iDi0uZOct 14, 2019Guide
If auto-updating kept happening via telnet method, factory reset the Orbi and give the hidden UI method a go?Tried the hidden UI method, was a little confused but figured it out. Checked this morning and it stayed at my old firmware that works. Thanks for your help.
- SW_Oct 15, 2019Prodigy
It's good to know that disabling Auto Firmware Update via Orbi UI works for you. Your experience/result will definitely help others, who might be in a similar pickle. Thanks for your feedback!
- Ragar99Oct 16, 2019Luminary
The original post says if the Orbi reboots the block on auto updating is lost. Have you rebooted yet?
- THizzle7XUOct 28, 2019Aspirant
The Orbi was just updated to firmware v2.5.0.38, and my EX7300 extender still cannot connect to the WiFi network to extend the network. The last firmware for Orbi where the EX7300 was able to connect fine was v2.3.1.60.
- FURRYe38Oct 28, 2019Guru - Experienced User
The 3700 may not be compatible with Orbi from the start. One user reported that the EX8000 didn't work. I found my EX7700s didn't work either. NG was able to make them compatible with a FW udpate for the EXs.
You'll need to contact NG support and see if they can do this for the 3700 model or not.
THizzle7XU wrote:The Orbi was just updated to firmware v2.5.0.38, and my EX7300 extender still cannot connect to the WiFi network to extend the network. The last firmware for Orbi where the EX7300 was able to connect fine was v2.3.1.60.
- THizzle7XUOct 28, 2019AspirantNo, the EX7300 was working perfectly with the Orbi since I purchased it UNTIL the Orbi was updated to v2.3.5.30. It's the whole point of this thread. In fact, downgrading the router only to the prior firmware allows the EX7300 to connect again. Except the Orbi forces the firmware to autoupdate.
Then this is something NG support needs to know. NG should be able to fix the EX with a FW update as they did for the 8000 and 7700s.
THizzle7XU wrote:
No, the EX7300 was working perfectly with the Orbi since I purchased it UNTIL the Orbi was updated to v2.3.5.30. It's the whole point of this thread. In fact, downgrading the router only to the prior firmware allows the EX7300 to connect again. Except the Orbi forces the firmware to autoupdate. - Blanca_OOct 28, 2019NETGEAR Employee Retired
Thankl you.
Blanca_O wrote:Hi THizzle7XU
I have sent you a message. Please check your inbox.
Blanca
Community Team - THizzle7XUOct 29, 2019Aspirant
Seeing as support is behind a paywall, posting to the Netgear forums is notifying support once you've owned your device longer than 3 months to 1 year...
- FURRYe38Oct 29, 2019Guru - Experienced User
Let us know if they upgrade your EX model.
THizzle7XU wrote:Seeing as support is behind a paywall, posting to the Netgear forums is notifying support once you've owned your device longer than 3 months to 1 year...
