BartKnowsit
Apr 22, 2018Tutor
Verizon Fios Gigabit Speed and Orbi RBR50 ISSUES????
I have Verizon Fios for internet. Usuing an Orbi RBR50 with a base and 2 satelites. The base is connected directly to my Verizon Fios modem. Had 100mbps speed. Worked well. Upgraded to a Smart...
Apr 23, 2018Guru - Experienced User
IF you have the 50 series, go over to NG support site and you can manuall download the v2.1.3.4 files and update the system youself. NG hasn't set this version to auto update as of yet. However is available for manual download.
Update the satellite first then router, then factory reset all then setup from scratch.
ubtchanova
Jun 14, 2018Aspirant
If I download a firmware update from NG instead of waiting forever for Verizon to provide an update for the ORBI system I just I purchased through them, will I harm my system or it's functionality? I can't use the Netgear "Circle with Disney" parental control app because it says I need to update my firmware.
- DarrenMJun 15, 2018Sr. NETGEAR Moderator
If you have the verizon specific Orbi you will need to get all firmware from verizon the standard firmware will not work on this.
DarrenM
