BartKnowsit
Apr 22, 2018Tutor
Verizon Fios Gigabit Speed and Orbi RBR50 ISSUES????
I have Verizon Fios for internet. Usuing an Orbi RBR50 with a base and 2 satelites. The base is connected directly to my Verizon Fios modem. Had 100mbps speed. Worked well. Upgraded to a Smart...
scopert
Jul 20, 2018Aspirant
ROUTER and 1 Sattelite.
waynealight
Jul 20, 2018Apprentice
a single wifi connection max speed is 433 mb/s. seeing 250-300 speed test is completely normal. you will never see full 1gb/s unless your wired. best case is a 2x2 connection on the orbi you may see 600 mb/s.
- scopertJul 21, 2018Aspirant
Thanks for your reply. What is a 2X2 connection?
- waynealightJul 21, 2018Apprentice2 send and receive connections. Google 2x2 WiFi ,3x3 WiFi, mimo. You will better understand what all the numbers really mean, what’s advertising bs and real world expectations
