quashck's avatar
quashck
Very strange problem with Orbi RBR50
Recently after doing nothing with my internet setup a new connection with no password appeared into the wifi list under the name ORBI96_Touch. I cannot connect to this nor do I see it in the orbi app. My normal connection is called ORBI96 so I assume it comes from my router? But now I also have strange disconnections after about 20 minutes of use. where I have to leave a room and go near a satellite or the router to reconnect. Any ideas what this orbi touch is?
  • plemans's avatar
    If you shut off a satellite, does it disappear?
    Then try shutting off the primary router to see if it disappears.
    Just trying to figure out if its actually your network (and what device) or not.
    • quashck's avatar
      quashck
      I just tested and disconnected both satellites but the ORBI_TOUCH connection is still there. And I forgot to add I already tried resetting everything with a pin on all satellites and router
      • plemans's avatar
        so if you shut off the satellites and the router, its still there?
        It'd seem to indicate it isn't from your system
