Tewkstus's avatar
Tewkstus
Initiate
Dec 16, 2017
VLAN tag group VLAN ID edit
Please advise on how to change VLAN ID for Internet port (not port 1, 2, or 3) on Orbi. Edit function fails.
Steps to reproduce:
Advanced Setup - VLAN/Bridge Settings
Check Enable VLAN/Bridge Group
Check By VLAN tag group
Check default Internet group (has VLAN ID 10)
Edit, change ID to 201, apply.
Change doesn’t stick, VLAN ID stays 10
1 Reply
  • I am having the same issue. Sounds like you are also CenturyLink. Have you figured out a solution?
