MV007's avatar
MV007
Follower
Nov 17, 2021
Voice Sync delays on some websites!
Hi All,
I have an RBR50 and RBR50S and ultimately for the last few years it has been working absolutely fine however recently I have been having issues with BBC iPlayer and some websites where there is a half a second or at times a second audio sync delay.
I am not sure what this can be but points to the network as I have checked on extrernal networks and this issue does not exist using the same hardware.
I have also tried my phone and three other laptops in my house on the same network and sadly the same issue with voice sync/delays are apparant.
Any one know what it could be and how to troubleshoot/resolve?
Many Thanks
  • FURRYe38's avatar
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
  • CrimpOn's avatar
    CrimpOn
    Where are you located?
    Using a VPN?
