NLok
Oct 29, 2018Aspirant
VPN bypass not working in Orbi RBK22
When I connect to my company VPN from home, I don;t get the DNS from work. My admins at work keep asking to set VPN bypass on my wifi router but there is no setting like that available. My previous router had no issues like this.
We use the Cisco umbrella client in our company setup and it forwards DNS queries to where needed.
The current workaround for me is to stop the unbrella client service and I am able to then get proper DNS response.
I have a ticket open with Netgear but so far did not get any resolution and they have not called back after August end.
Can anyone tell me how to setup VPN bypass on this router? I am contemplating returning this router if this is not fixable in few weeks.
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?Not sure if this is any help:
https://community.netgear.com/t5/Orbi/Orbi-VPN-no-network-access/m-p/1644658#M41983
- NLokAspirant
No error, when I try to ping my companies Hosts (after conencting to Cisco VPN) it sends request to internet instead of local DNS and hence I cannot connect to company resources. I have to turn off the umbrella client and then I get local DNS resolution.
It was never working since day one of this router purchase. It was working with my D-Link router with no special setup.
I have Spectrum internet which comes to their Modem setup in bridge mode, Orbi router connected to 1 port of the Modem.
Something to try, set the ISP modem back to router mode, then try using the Orbi in AP mode to see if the problem continues.
You can also try setting the Orbi as router while the ISP modem is in router mode and place the IP address the Orbi gets from the modem into the modems DMZ and see if the problem continues.
Any progress on this?
