5_D
Nov 14, 2025Aspirant
VPN Ports Closed -> VPN Timeout
Trying to setup VPN on RBR50 router connected to SB1683 cable modem. Testing VPN connection on OpenVPN IOS via cellular. Public IP matches that of router settings. Every time testing the VPN it times...
- Nov 18, 2025
Although you enter the DDNS hostkey into the orbi UI, you need to edit the configuration file to your dynamic dna host name.
remote all.ddnskey.com 12973 -> should be-> remote yourhost.yourdomain.com 12973
