5_D
Nov 14, 2025Aspirant
VPN Ports Closed -> VPN Timeout
Trying to setup VPN on RBR50 router connected to SB1683 cable modem. Testing VPN connection on OpenVPN IOS via cellular. Public IP matches that of router settings. Every time testing the VPN it times...
- Nov 18, 2025
Although you enter the DDNS hostkey into the orbi UI, you need to edit the configuration file to your dynamic dna host name.
remote all.ddnskey.com 12973 -> should be-> remote yourhost.yourdomain.com 12973
5_D
Nov 15, 2025Aspirant
The smartphone config file already had verb 5. I tried with windows via Verizon hotspot. I had to edit the config for tun and remove lines for it to work. I have tried rebooting after changing: IPv6, UPnP, port #, traffic meter, port scanner.... I also tried erasing to no avail. I have IPv6 enabled for this test so I am not sure why it is saying false.
client
dev tun
proto udp
nobind
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 5
sndbuf 393216
rcvbuf 393216
[Nov 15, 2025, 15:51:13] OpenVPN core 3.11.3 win x86_64 64-bit OVPN-DCO built on Sep 16 2025 15:58:53
⏎[Nov 15, 2025, 15:51:13] Frame=512/2112/512 mssfix-ctrl=1250
⏎[Nov 15, 2025, 15:51:13] EVENT: RESOLVE ⏎[Nov 15, 2025, 15:51:14] Contacting x.x.x.x:12973 via UDP
⏎[Nov 15, 2025, 15:51:14] EVENT: WAIT ⏎[Nov 15, 2025, 15:51:14] WinCommandAgent: transmitting bypass route to x.x.x.x
"host" : "x.x.x.x",
"ipv6" : false
loop
⏎[Nov 15, 2025, 15:51:53] Connecting to [all.ddnskey.com]:12973 (x.x.x.x) via UDP
⏎[Nov 15, 2025, 15:52:03] Server poll timeout, trying next remote entry...
⏎[Nov 15, 2025, 15:52:03] EVENT: RECONNECTING ⏎[Nov 15, 2025, 15:52:03] EVENT: RESOLVE ⏎[Nov 15, 2025, 15:52:03] Contacting x.x.x.x:12973 via UDP
⏎[Nov 15, 2025, 15:52:03] EVENT: WAIT ⏎[Nov 15, 2025, 15:52:03] WinCommandAgent: transmitting bypass route to x.x.x.x
"host" : "x.x.x.x",
"ipv6" : false
⏎[Nov 15, 2025, 15:52:04] Connecting to [all.ddnskey.com]:12973 (x.x.x.x) via UDP
⏎[Nov 15, 2025, 15:52:13] EVENT: CONNECTION_TIMEOUT BYTES_OUT : 840
PACKETS_OUT : 60
CONNECTION_TIMEOUT : 1
N_RECONNECT : 5
⏎[Nov 15, 2025, 15:52:13] EVENT: DISCONNECTED ⏎
Nmap scan report for c-x-x-x-x.hsd1.or.comcast.net (x.x.x.x)
Host is up.
PORT STATE SERVICE
12973/udp open|filtered unknown
12974/udp open|filtered unknown
Nmap done: 1 IP address (1 host up) scanned in 5.62 seconds
