Boatguy54
Dec 19, 2017Guide
WAN access to Orbi
1) Is there a way to change the user name? Under Advanced settings I can change the password, but not the user name (2.1.1.16)
2) When I access via the web interface, is this going through my LAN or via NetGear and the WAN? If WAN, I would like to disable acces from the WAN.
- aazVirtuoso
Unlike some other mesh systems out there, Orbi is not controlled from the cloud - so LAN only. Unless you enable control via internet, and even that you can restrict to a specific IP.
Great! How do I change the user name?
