kcampbel44145's avatar
Jun 07, 2020
Want to use ethernet on Multiple Orbi
I purchased the Orbi Tri-Band WIFI Whole Home Wife System.  It comes with the AC3000 Router an AC3000 Satellite.  I have ethernet in multiple rooms in my house and was hoping I could connect each of these to an ethernet.  It turns out the satellite simply is meant to boost the signal from the primary router.  Did I purchase the wrong product?  So far results are good but was hoping the results would be outstanding.  Given that I have three ethernet cables in my house all coming back to modem in basement, I would have a solution that would leverage that.  Thank you!
  • FURRYe38's avatar
    If you have ethernet in various rooms in your home, then these rooms and there ethernet connections should be connected to a patch panel in a closet or room some place, then these connections would and will need a Gb LAN switch to connect too. This switch can be connected behind the Orbi RBR router thus providing wired internet access connections to the rooms that have wire ethernet LAN ports on the wall.
    I have this same configuration in my home.
    You can wire connect the RBS as well:
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
    • kcampbel44145's avatar
      kcampbel44145
      Thanks Furry.  But if I don't want to use a patch panel and simply want to plug the satellite into the ethernet, it looks like I simply connect them through the ethernet to create an "ethernet backhaul connection"?  It says to do so with "star topology".  Can you explain what start topology is?  Also, I assume I will get a faster connection than simply using the satellite wirelessly right?  Thanks again
      • FURRYe38's avatar
        You'll need to find out where the end points from the rooms go to. Yes you don't have to use a patch panel. If you know the wire from one room where you want to place the RBS and that wired goes to where the RBR is, then you can connect that wire directly to the back of the RBR. Then connect the RBS to the LAN port in the remote room you want the RBS placed in.
        https://en.wikipedia.org/wiki/Network_topology
