UnhappyOrbiUser
Nov 11, 2018Star
WARNING: Firmware 2.2.1.210 is junk
If you're dealing with poor WiFi performance, frequent disconnects and so on, you aren't alone, there are various other threads on this topic. Here's what you need to know:
Check if your Orbi...
Nov 16, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
This worked for this user, Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
Den_ wrote:
Thanks for the links. Since the last update, I have had to turn off my satellite as it was continuously disconnecting. The previous firmware worked fine.
UnhappyOrbiUser
Nov 16, 2018Star
Hey FURRYe38, please do not hijack this thread for troubleshooting, thanks.
- Chi7Dec 17, 2018Star
UnhappyOrbiUser that guys the worst. get rid of the Orbi, like I and others did. It's painful and not worth the headache.
