knewbee
Oct 05, 2018Aspirant
Weak Signal to Satellite Right Next to Router!
I just purchased the RBK50 router and satellite kit and set it up according to instructions. I'm getting a signal ok to my laptop 10 feet away, speedtest showing 155mbps download and 11.8 upload.
Oct 05, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Any Wifi Neighbors near by? If so, how many
So why is the satellite LED showing amber when it's right next to the router, instead of blue?
