mswells
Jan 28, 2019Aspirant
Web login won’t display
Just installed my Orbi RBK53, and am able to get the app to work fine along with the web GUI login, on my iPhone....but can’t get the login screen on my hardware desktop. I have the Orbi in AP mode, ...
mswells
Orbi internet port going to router. I can login to the main, and 2 satellites, if I use the i.p address associated with each device.
ekhalil
Jan 28, 2019Master
- mswellsJan 28, 2019AspirantHost is not recognized as an internal or external command. I tried ping command and am able to get reply’s back.
- ekhalilJan 28, 2019Master
mswells wrote:
Host is not recognized as an internal or external command. I tried ping command and am able to get reply’s back.So you tried ping to orbilogin.com and you got a reply? If yes, from which IP address did you get the reply?
When I try ping orbilogin.com I get the following:
$ ping orbilogin.com
PING orbilogin.com (192.168.1.1): 56 data bytes
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=4.047 ms
- mswellsJan 28, 2019AspirantLooks to be an outside address: 184.168.131.241
- FURRYe38Jan 28, 2019Guru - Experienced User
Try this, remove the LAN cable between the Orbi and the main host router temporarily. Go in and configure the Orbi for AP mode. After it reboots, can you log in using orbilogin.com then?
Set back to AP mode after trying this.
