mswells
Jan 28, 2019Aspirant
Web login won’t display
Just installed my Orbi RBK53, and am able to get the app to work fine along with the web GUI login, on my iPhone....but can’t get the login screen on my hardware desktop. I have the Orbi in AP mode, ...
mswells
Host is not recognized as an internal or external command. I tried ping command and am able to get reply’s back.
ekhalil
Jan 28, 2019Master
So you tried ping to orbilogin.com and you got a reply? If yes, from which IP address did you get the reply?
When I try ping orbilogin.com I get the following:
$ ping orbilogin.com
PING orbilogin.com (192.168.1.1): 56 data bytes
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=4.047 ms
- mswellsJan 28, 2019AspirantLooks to be an outside address: 184.168.131.241
- mswellsJan 28, 2019AspirantYeah, I can login just fine from another pc that is Wifi only.
Does it matter that my other pc is hardwired into the port on my ASUS router as opposed to the Orbi Ethernet port ? - ekhalilJan 28, 2019Master
Does it matter that my other pc is hardwired into the port on my ASUS router as opposed to the Orbi Ethernet port ?Yes, since Orbi is in AP mode it uses the DNS server of your upstream router (the ISP router), so when browsing to orbilogin.com from a wired device you will go directly to the upstream router and get the DNS to resolve the address there, and obviously it will not return your Orbi's private managment IP address!
On the other hand when browsing from a wifi devices the request will pass through Orbi and get the "local DNS" resolve the orbilogin.com to the correct private IP address.
This is not a fault and is working as it should! :)
- ekhalilJan 28, 2019MasterAlso in AP mode Orbi's WAN and LAN ports are bridged so I don't think it matters if wired devices are physically connected to Orbi or the upstrram router.
- Chuck_MFeb 12, 2019Mentor
I have a feeling the PC he is trying to hit orbilogon.com with is not on HIS wireless network, but another wireless network (his neighbor??)
Can you go to WHATISMYIP.COM on both machines in your house and compare the results? They SHOUld be the same... if they are not, one of your machines is on a stray network.
- ekhalilFeb 13, 2019Master
Hi Chuck_M , this is a special case, when Orbi is in AP Mode the LAN and WAN ports are bridged, so wired devices to the Orbi router will not see Orbi at all since they -in a way- are directly connected to the ISP router! Therefore they will go directly to the ISP router's DNS and thus will never be able to get "orbilogin.com" resolved to the private IP address of Orbi's management port.
Those devices (wired device to Orbi router in AP Mode) should use the IP address of Orbi to reach to the web GUI and not orbilogin.com
- Chuck_MFeb 13, 2019Mentor
Good point, I didnt think of that. If you do this, how would you reconfigure your orbi out of AP mode? (e.g. get to the gui?)
Chuck_M wrote:
............. If you do this, how would you reconfigure your orbi out of AP mode? (e.g. get to the gui?)
- Using orbilogin.com from any device connected via wifi to Orbi or wired devices to the satellites
- Using the IP address of Orbi (assigned by the ISP router). That's why it's good to make a DHCP reservation for Orbi in the ISP router when you set Orbi in AP mode.
Thanks, never used it as an AP... this is good to know. +1
- mswellsFeb 14, 2019Aspirant
I ended up just creating an entry for orbilogin.com, in my windows Hosts ile....works fine now.
