orbikrush's avatar
orbikrush
Website Created through Hostinger getting Blocked by Orbi RBK50
I recently created a website through Host provider Hostinger. I can access the website fine, except when connected to my home WIFI.  A coworker had the same access issues and we both confirmed we both have Orbi Routers.
I don't have Netgear Armor installed and most of my settings are pretty generic.
I attempted to allow all HTTPS per another thread, but that did not work.  Any other suggestions?
  • Would it be possible to make a screen shot of the web browser message that describes the failure to connect?
    Sometimes it is helpful to confirm that the router is able to resolve the website URL into an IP address.
    Many web sites respond to the Internet Message Control Protocol (ICMP, often known as 'ping').
    A command window on the computer (Windows? Mac? Linux?) should be able to resolve the URL into IP.  i.e.
    ping URL      (for example, ping ford.com)
    The key is not that the web site responds to ping, but that the URL gets translated into an IP address.
    The default configuration for Netgear routers is for the router to use the DNS server specified by the Internet Service Provider (ISP).  It is a pretty common practice to manually set DNS servers to a couple of the largest ones, such as:
    1.1.1.1 (Cloudflare) and 8.8.8.8 (Google).
  • CrimpOn's avatar
    CrimpOn
      • CrimpOn's avatar
        CrimpOn
        Thanks.  That points toward a DNS issue. Can you try using those two DNS servers?
