Benjimcb
Apr 29, 2018Aspirant
Weird behavior ISP router
Hello,
I have a RBK23 Orbi kit for few days and I encountered weird behavior.
My ISP Router is connected to 16 ports Dell unmanaged switch and all my devices are all connected to this switch....
Benjimcb
"Well that was a typo on my part. Sorry, Mfr and model# of the switch and main host router? ALso whats the Mfr of the ISP Modem and model#?"
My ISP is a french one : SFR and the Modem it's a the ISP Modem "SFR LABOXV3B" : Sagemcom La Box
http://www.sagemcom.com/fr/broadband/decodeurs/cable/la-box/
"Might also try connecting the Sateliite directly to the Orbi router instead..." :
My Eth Backhaul Satelite is connected directly to the Orbi Satelite. It's for this reason that I'm using the WAN Port of the Orbi Router (RBR20 = 1 WAN port and 1 Eth Port).
"The WAN to LAN and LAN to LAN is how the physical connections is being done on the Orb router in AP Mode, are you connecting the Orbi using the WAN port on the back of the Orbi or the LAN port when connecting the Orbi to the main host router? "
So I'm using WAN port directly to the OSP
Benjimcb
My ISP Box is this one (English version) : http://www.sagemcom.com/broadband/set-top-boxes/cable/the-box/
I can print screen the web UI if needed.
