rhester72
Dec 12, 2016Virtuoso
What are the parameters for automatic firmware update?
What, exactly, are the parameters for which a router and/or satellite will auto-update? I know the initial firmware release had a bug that prevented it from working, but I can honestly say I've n...
MarkC1024
Dec 12, 2016Luminary
I don't believe it will automatically apply the update without you telling it to. What it will do is look for the updates and inform you they are ready to be installed. It's not a good idea to have this type of work done unless you are ready to do so and not needing your network for a few minutes. Just look in the Advanced tab under Administration.
