johnny5126
Mar 01, 2019Aspirant
What happened to firmware 2.3?
The other day I upgraded my RBR50, RBS50 & RBR40 to firmware 2.3.0.32. I had to use the 2.2.1.212 update first on the RBR50 to update to 2.3 and got it from on here on a dropbox account. Now when I...
Mar 01, 2019Guru - Experienced User
v32 is there:
https://www.netgear.com/support/product/RBK50.aspx#download
at the top of the support page.
"Top Support Articles
RBR50 / RBS50 Firmware Version 2.3.0.32"
All 20 and 40 Series can be found here:
johnny5126
Its not there for the RBR50.
- ekhalilMar 02, 2019MasterPlease use the pages for RBR50 and RBS50 instead:
RBR50: https://www.netgear.com/support/product/RBR50.aspx#download
RBS50: https://www.netgear.com/support/product/RBS50.aspx#download - FURRYe38Mar 02, 2019Guru - Experienced User
- tagteamMar 02, 2019Virtuoso
Does anyone know what the deal is with this image? I type in "RBK5" and get all of the variants with each having a version with "NETGEAR Armor" and another without.
Each obviously takes you to the download page for the firmware downloads. Is there a difference?
NO FW difference. Just the K means Kit and each Kit has either 1 or 2 satellites in the box.
FW is the same for the 50 series systems.
