jasonwong
Nov 20, 2018Aspirant
what is different between RBR20 and RBR40
Hi,
I know RBR20 only 1WAN port and 1LAN port, RBR40 more LAN port, RBR20 size smaller, apart from that, what is different?
Thanks in advance.
DickDuke
Nov 20, 2018Apprentice
I actually own both of these units. The main differences you’ve already noted, size and number of ports. I believe the RBR40 May have more flashable memory too.
My experience may be unique to my RBR40 unit, but it seems to have way more difficulty synching with my 3 Orbi satellites. So much so, that I’ve given up on it for now, and I’m using the RBR20 with a 5 port switch instead of the RBR40 with its built-in switch. The RBR20 is rock solid.
- DickDukeDec 03, 2018Apprentice
UPPDATE:
Tried my RBR40 out again today. All 3 satellites connected. All connections are good. Was able to eliminate one of my 4 port switches.
If everything remains stable over the next few days, I'll be a very happy camper!
My Setup:
Rogers Hitron 200/16 + RBR40 (from RBK33)+ RBW30 + RBS20 + RBS20 + 2x TPLink Powerline
