claus_hansen_dk's avatar
Feb 22, 2017
What is the correct latest firmware version
I just used the router autodiscover function to download and install the latest fw package (1.5.0.12) but got really concerned when I went to netgear.com to read the release notes and found that the latest version acccording to the webpage is 1.4.0.34 !!!
What is it I got on my router ? Can someone point me to the release note for 1.5.0.12 and can someone from Netgear please explain what is going on ?
(my concern is of course that I got a beta or compromised image on to my router, while I am hoping is just very bad discipline on the netgear update documentation !!!!!)
Thanks
  • Netgear's firmware-info webpage for Orbi always lags a day or two or three behind when an update is made available via the router's own firmware-update check feature (auto-discover) - that's not unusual at all.  I'm not saying that makes any sense, but it is what it is - just seems to be how they roll.
    When I updated mine earlier this morning, I was able to click and see the release notes, but I don't remeber those details (I'm not at home now to check again)...  I don't recall seeing anything too crazy in there, so I pulled the trigger.
    My Orbi didn't self-implode, so it seemed OK to me :)  I'll play around with it more tonight when I get back home.
    Current Version:V1.4.0.34
    New Version:V1.5.0.12
    Release Notes:
    [New Features] Supports VLAN and bridging on the Orbi router.
    [New Features] Supports IGMP proxy.
    [New Features] Allows users to enable or disable the "Allow guests to see each other and access my local network" feature in AP mode.
    [Bug Fixed] Fixes bugs and security issues.
    [Enhancements] Improves the firmware update process.
    • I was looking for real release notes, not just the headlines.....
      Eg - which security issues are solved !
      Release Notes:
      • Hirrdgoon's avatar
        Hirrdgoon
        Apprentice
        wishing wired backhaul was on this list........ :smileymad:
