ryanpc's avatar
ryanpc
Guide
Mar 21, 2019
What is the latest firmware I should be running on my RBR50?
Current firmware 2.2.1.210 (says there are no updates)
From netgears page however it appears there is version 2.2.1.212 and 2.3.0.32 available
Any help is appreciated
  • .32 is current version, but you must first load the intermediate firmware that you identified.
    The update service inside of Orbi is not reflecting these newer versions yet as they are manual updates only.
    Do your satellites first, then your router.
    • ryanpc's avatar
      ryanpc
      Guide
      Should I just wait for the auto update in your opinion? I don’t really care much for new features but obviously want to have the latest security patches
      • CrimpOn's avatar
        CrimpOn
        If you are not seeking a solution for specific problems with Orbi, there is no need to perform a manual update.  Netgear receives reports of "issues" with products and their engineers work on changes to the firmware to address those concerns.  At some point, they decide their efforts need to be exposed to a test audience, so they release a "Beta" version to a select group of adventurous users.  If that test seems to go well, they publish the firmware so others can perform a manual update.  A number of people on this community forum have concluded that the "32" firmware solves their problems.  As one might expect, a number of people have concluded exactly the opposite: i.e. the "32" firmware is worse than the "210" and they have gone back.  At some point, one of two things will happen:  Netgear will decide to push an automatic update to all Orbi devices OR they will decide that "32" is not good enough and they will come up with more code changes and go through the process again.
        I am happy with "32", although I didn't have any serious issues with "210", either.
        "If it ain't broke, don't fix it."
