sigswi
Mar 14, 2017Aspirant
what is the latest firmware version V1.8.0.6 or 1.5.0.12
hi i just got 2 orbi sets today, i actually plan to install only 1 router and 2 satellites (but satellites were not available for sale on their own in switzerland) I am confused about the firmware ...
- Mar 15, 2017
actually found the solution
the trick is to ignore the upload option on the interface, choose update directly and upload through the pop screen that appears afterwards.
seems to work :)
Pesto242
Mar 14, 2017Star
I updated today...I knew I shouldn't considering everything was working fine..
I have updated my Orib system from the very start. I had very few issues, and always was able to update and keep my old configuration.
Not this time. Completely deleted my entire configuration and started from the "Welcome to Orbi" screen with a wired laptop. Reset everything, reconfigured everything (very difficult with all my port forwarding and static IP's).
Still having lots of weird issues on the network. I highly recommend from anyone doing an upgrade with 1.8.0.6 unless you are in Korea.
- wchpMar 14, 2017Luminary
Before doing a firmware update, best practices is to make a backup of the current config.
Log in to the Orbi router and select the Advanced tab.
Select "Administration" then "Backup Settings"
Click on the backup button.
The backup file downloads almost instantly.
When it comes to firmware updates on any device: I hope for the best, but I plan and prepare for the worst.
