ERNYE1
Dec 31, 2016Initiate
What is the maximum number of Netgear Orbi Satellites that can be supported by Netgear Orbi Router?
- Jan 03, 2017
Hello Ernye1
It can support up to 3 satellites and 1 main router.
DarrenM
mikegyver
Jan 16, 2017Tutor
HI,
I see that it was stated that max of 3 satellites, but I am having a real hard time getting the 3rd satellite connected.
Is it me or there's wrong info out there?
DarrenM
Jan 18, 2017Sr. NETGEAR Moderator
Hello mikegyver
What issues are you running into when setting up the third?
DarrenM
- mikegyverJan 18, 2017Tutor
Darren,
I got it going.... brought all the satellites into the same room and disconnected the 2nd one that did work, then sync up the third, then brought the 2nd one back online.
thanks
- Mikey94025Jan 18, 2017Hero
Just another data point -- I have 3 satellites and had no extra problems installing the 3rd. (Why do I have so many? To improve connectivity with a couple outdoor wireless cameras where outside connectivity is much worse, presumably due to house construction interference)
