ERNYE1
Dec 31, 2016Initiate
What is the maximum number of Netgear Orbi Satellites that can be supported by Netgear Orbi Router?
- Jan 03, 2017
Hello Ernye1
It can support up to 3 satellites and 1 main router.
DarrenM
Elvisj
Feb 17, 2017Star
So if i cannot add a 4th satellite, can I add a Netgear wi-fi extenders to the network to get more range? I have a workshop away from the house with music and TV while I work there. It has an Ethernet wire, so can I add another 16 port switch from one satellite?
DarrenM
Feb 21, 2017Sr. NETGEAR Moderator
Hello elvisj
Yes you can use a extender for the workshop but it will not auto switch to that network when you move out there it will need another SSID and you will manually connect your device to it. Yes you could also use a switch if you have Ethernet running out to that area.
DarrenM
