ERNYE1
Dec 31, 2016Initiate
What is the maximum number of Netgear Orbi Satellites that can be supported by Netgear Orbi Router?
- Jan 03, 2017
Hello Ernye1
It can support up to 3 satellites and 1 main router.
DarrenM
robbskittlesII
Mar 16, 2017Guide
I myself have 3 satellites working, and also think you can add a fourth but haven't tried it yet. Waiting for confirmation to shell out another $200.
robbskittlesII
Apr 03, 2017Guide
- peteytestingApr 03, 2017Hero
you must have a massive house to need to run the orbi router and 2 other sats indoors and then the garage one
you do understand that too much wifi isnt a good thing right , placement and location are the key to give the right overlap so clients will roam
- NETthisGEARApr 07, 2017Apprentice
Hey guys. So it appears you can defintely use more than 3(people are doing it in this thread currently), however if NETGEAR is mentioning that 3 is the number, don't be upset if an issue occurs at some point since they clearly are saying 3 here:).
It doesn't hurt to hear people reporting success stories on the Orbi handling 4+ satellites and the fact that we haven't heard back from them. Sounds encouraging.
If you have a disposabal income it is certainly worth trying the Orbi with as many satellites as possible. I wouldn't see why you wouldn't. You can buy individual satellites for the Orbi as well.
- robbskittlesIIApr 30, 2017Guide
I think i will make the 4th sat purchase soon. I really don't need it but i would like hardwire connections in my room. I haven't had any connection problems like as many people have reported. I check my sats online and physically everyday to make sure. All 3 sats work just fine. Just Updated to 1.9.1.12 today and everything looks the same as in no connection problems. Does anyone know where i can find the release notes from the new update. -Thanks-
- JoshGMay 02, 2017Guide
robbskittlesII wrote:
Thanks Rob, like mine, yours shows just 3 satellites. I'm hoping you or someone else running 4 can show a screen like that showing 4 working satellites. fingers crossed... let us know how it goes if you decide to try it!- CollingsworthMay 03, 2017Guide
- JoshGMay 14, 2017Guide
THANK YOU Collingsworth! That's the first visual proof of a 4-satellite system operating without any problems. Very cool.
Can you say if your system has been reliable? Are you on 1.9.1.12?
