ERNYE1
Jan 01, 2017Initiate
What is the maximum number of Netgear Orbi Satellites that can be supported by Netgear Orbi Router?
- Jan 03, 2017
Hello Ernye1
It can support up to 3 satellites and 1 main router.
DarrenM
NETthisGEAR
Apr 07, 2017Apprentice
Hey guys. So it appears you can defintely use more than 3(people are doing it in this thread currently), however if NETGEAR is mentioning that 3 is the number, don't be upset if an issue occurs at some point since they clearly are saying 3 here:).
It doesn't hurt to hear people reporting success stories on the Orbi handling 4+ satellites and the fact that we haven't heard back from them. Sounds encouraging.
If you have a disposabal income it is certainly worth trying the Orbi with as many satellites as possible. I wouldn't see why you wouldn't. You can buy individual satellites for the Orbi as well.
robbskittlesII
Apr 30, 2017Guide
I think i will make the 4th sat purchase soon. I really don't need it but i would like hardwire connections in my room. I haven't had any connection problems like as many people have reported. I check my sats online and physically everyday to make sure. All 3 sats work just fine. Just Updated to 1.9.1.12 today and everything looks the same as in no connection problems. Does anyone know where i can find the release notes from the new update. -Thanks-
