SpartanMurph
Mar 06, 2021Guide
Where to find an add-on satellite?
Currently have this
https://www.amazon.com/dp/B07CQDHPFT/ref=cm_sw_r_cp_apa_fabc_AQKN9PMQH3Q13JR1N5T2?_encoding=UTF8&psc=1
Where can I buy one add-on satellite?
Can't seem to locate one anywhere.
That Amazon link is for the RBK23 package and the model checked is the RBK53.
Either way, any of the original Orbi satellites will integrate. With the 2016 Orbi product line now "long in the tooth", it is becomming more and more difficult to find satellites. All I find on Amazon today are the RBS20 for $200 and the RBS40V (voice) for $160. Both are entirely compatible.
- There was no drop down selection for the RBK23. So I chose the closest thing.
Thanks for your response. Essentially, they're out of production and hard to find.
The whole system was $300.00. can't imagine paying $300 for one add-on.
I'll hold off and invest in a whole new - newer wifi6 system in a year or two.- FURRYe38Guru - Experienced User
You can get the RBS40v which is the same as the RBS20 accept it has voice controls fo 160 or 80 for use used one:
Well worth it IMO.
