Brenkj
Dec 04, 2018Aspirant
Which Orbi System Should I Buy for My House
I'm looking into buying an Orbi system and I'm trying to figure out which one is best for my house. The house is about 50 years old. It consists of 2 floors of about 2,000 sf each, plus a 3rd floor that is about 1,000 sf. We don't have a basement. The third floor is basically for storage and for the kids to go play video games, so I'm not as concerned about having amazing WiFi up there; just adequate would be fine.
Can anyone recommend the Orbi system that would be best for my needs, while not spending a bunch of money unnecessarily?
Thanks.
I presume a base router and 1 satellite will be good to start with.
You can review what NG recommends here:
https://www.netgear.com/orbi/wifi-systems.aspx
30 feet is recommended in between base router and satellite(s) to begin with depending upon building materials.
- DickDukeApprenticeThe giant book company has the RBK23 System (router plus 2 satellites) on sale right now.
It would be ideal I think as it offers a lot of placement options.- BrenkjAspirantThanks for the heads up. What the difference between the small satellite units that come with the RBK23, and the larger satellite unit that comes with other packages?
There are two LAN ports in back of the smaller RBS20s while you get 4 LAN ports in back on the RBS50s.
