jhoff909's avatar
jhoff909
Apprentice
May 18, 2020
Which satellite's can I add to an RBR50v2?
Hi,
I have an RBR50v2 and an RBS50 and am looking to add another satellite.  $210 to just add a satellite (RBS50) seems high.  Are there other options?
Thanks!
Jerry
  • Yes, any Orbi satellite except for the new RBS10 will integrate with your Orbi system.  (RBS20, RBS40, RBW30, RBS50Y - expensive!)
    If you need WiFi coverage for one specific device that never moves, you could purchase a simple "WiFi extender" for under $50.
  • CrimpOn's avatar
    CrimpOn
