yeahman
Dec 08, 2019Tutor
Which Satellites can I add
Hi I have the following : AC2200 Mini Orbi Router(RBR40) with rbw30 satellite - but would like to add another satellite - please could you advise what versions of satellites I can add to this, is there a hardware compatibility list plese. Could I purchase a better model like the rbw50 is there is such a thing and get better coverage from it perhaps?
Also it strangely seems that buying a new router and satellite is cheaper than buying just a satellite alone - can I add another router too perhaps to extend the system? I take it I can sell the router alone and keep the satellite - it's not tied into that particular satellite is it
Much thanks for any help
Cheers
Andy
1 Reply
All the satellites are compatible. But if your main router is the rbr40 you're a bit constrained by the 866mbps backhaul. the rbs50's have the faster backhaul but your primary router will limit it down.
So again, every satellite should work with yours. If the rbs50 is cheaper, go that route. but if it isn't, you won't see a benefit.
