Fwilliams
Dec 08, 2018Aspirant
Which Wifi should I be using?
I don’t seem to be getting the results I would have thought (please see picture) also am I supposed to connect to the new WiFi network only and not my original one....? I guess I thought all things Wi...
Dec 08, 2018Guru - Experienced User
Disable all old wifi and use the new from the Orbi...
- FwilliamsDec 09, 2018AspirantWhen I disable the router and WiFi stuff will that impact my cable as I’m on AT&T U-verse?
- FURRYe38Dec 09, 2018Guru - Experienced User
No, once you disable wifi on the ATT router, and get the Orbi setup in AP mode behind the ATT router, just connect ALL devices to the ORbi. You can even use the same SSID name and PW on the Orbi if you want too. Just disable ALL wifi on the ATT router is all.
