Fwilliams
Dec 08, 2018Aspirant
Which Wifi should I be using?
I don’t seem to be getting the results I would have thought (please see picture) also am I supposed to connect to the new WiFi network only and not my original one....? I guess I thought all things Wi...
Dec 09, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Fwilliams wrote:
I don’t seem to be getting the results I would have thought (please see picture) also am I supposed to connect to the new WiFi network only and not my original one....? I guess I thought all things WiFi in my home would be fast but right now I’m not seeing anything noticeable...
Oh, am I supposed to hook smart home devices to my original WiFi network or the new one by Orbi? Lastly I thought I’d see theee different networks not just one?
Help please!
- FwilliamsDec 09, 2018AspirantThanks much, based on your reply I will just go ahead and pack this baby up and take it back... I thought it would be a bit more user friendly... just don’t have the time or energy to learn it... I know this is an Orbi forum but are there any options that are more plug and play ready?
Thanks again for your help...- ekhalilDec 09, 2018Master
Thanks again for your help...You will get the same issues with any other router. If you have conflicts in the radio network settings or in the routing functionality you will see similar issues with any other product.
- FwilliamsDec 09, 2018AspirantThanks much, are there any other instructions for this stuff... I didn’t see all of this in the instructions anywhere?
- FURRYe38Dec 09, 2018Guru - Experienced User
Try the suggestions. If you want the orbi to work with another host router, then user AP mode. Thats simple to configure on the Orbi.
Try suggestion #3.
