Fwilliams
Dec 08, 2018Aspirant
Which Wifi should I be using?
I don’t seem to be getting the results I would have thought (please see picture) also am I supposed to connect to the new WiFi network only and not my original one....? I guess I thought all things Wi...
Fwilliams
Dec 09, 2018Aspirant
Thanks much, based on your reply I will just go ahead and pack this baby up and take it back... I thought it would be a bit more user friendly... just don’t have the time or energy to learn it... I know this is an Orbi forum but are there any options that are more plug and play ready?
Thanks again for your help...
ekhalil
Dec 09, 2018Master
You will get the same issues with any other router. If you have conflicts in the radio network settings or in the routing functionality you will see similar issues with any other product.
- FwilliamsDec 09, 2018AspirantThanks much, are there any other instructions for this stuff... I didn’t see all of this in the instructions anywhere?
