Mike734
Aug 06, 2017Star
Why does the firmware status say, "update failed" for my RBS50?
When checking the firmware version of my router, two satilite system the router says it has 1.12.0.18 nstalled but the satilites say update failed. Both seem to be working but with less range than be...
Mike734
Aug 07, 2017Star
I KNOW what version is installed. I want to know why it says, Update Failed.
peteytesting
Aug 07, 2017Hero
then if you KNOW what the fw version is reporting on the sat's themselves and not just what is reported in the router gui then dont worry about it , its obviously just a reporting error
- Mike734Aug 07, 2017StarWhy? Two reasons. One is to report yet another bug in the latest firmware. Also, I believe this kind of problem can indicate other, less obvious problems.
I believe this latest firmware is pathetic and diminishes the value of this expensive purchase.
