prodport's avatar
prodport
Initiate
Oct 17, 2019
Why isn't ORBI Login Secure
I like the product but why is the browser login for Orbi insecure?  (http://orbilogin.net/adv_index.htm).  IF I change to HTPPS I get a different error.
I don't use the phone app becasue I find the login process cumbersome and it never completes the task of checking for network updates. I also find it confusing having to have both an Orbi login and Netgear.
  • CrimpOn's avatar
    CrimpOn
    Thank you for joining "The Choir".  These have been on-going issues for months now:
    • (Literally) since "the beginning" consumer WiFi routers have had unsecured web administration (http).
      My take was that a person had to be "on the inside" to reach the router web pages,
      and Remote Access is turned off by default, so the risk might have been determined to be minimal.
      In the last couple of years, there has been a huge push to encrypt almost all web sites, and Netgear is slow to adapt.
    • Netgear does support encrypted access to the web administration, through https,
      but unfortunately Netgear let their Ensure Certificate lapse in August and has not released updated firmware
      with a new certificate.  People are seriously annoyed when their web browsers now refuse to connect to the Orbi
      because of this.
    • Netgear is also joining the move to cloud based management with the Orbi app.
      There are many (many) devices now that can be managed only with a web app via the cloud.
      The Orbi "app" is slick, but (a) incomplete, (b) buggy, and (c) requires an internet cloud connection
      that many of us would rather avoid.
    I think your observations are "spot on."
    • FURRYe38's avatar
      One issue is that there are certificates that need to be on local devices that would need to be effected for HTTPS to work on any router web page. Most router mfrs don't or probably won't try to support this as this would take more resources and support and with all kinds of various devices, PCs and browsers, this could be a monumental case to solve for just accessing a routers web page with https. Something until something gets exposed with using HTTP on the LAN side of the routers web page, just hasn't been a problem up to this point. Unless you have a known trouble maker on your LAN side, it's something thats not critical. I've never seen any problems stemming from use of HTTP with a routers web page yet.
      Those router MFrs that do well, thats good as well. I would be nice if we could use either mode however.
      • CrimpOn's avatar
        CrimpOn
        I think this is the whole point of the "certificate" issue.  Netgear has implemented encrypted web access on the Orbi and included a certificate that was good from August 2, 2016 to August 2, 2019.  (Remote Access requires using https.)  So, yes, they shipped thousands of products that all had a valid security certificate.  Their failure to anticipate the certificate expiring and getting a new certificate out to the routers is what has caused so many web browsers to complain since August 2.
  • Retired_Member's avatar
    Retired_Member
    Maybe I don't understand, but why are we concerned about a secure ORBI login?
    I login with my home browser to my home router...??
    All the communications and editing is done on my side of the router.
    • CrimpOn's avatar
      CrimpOn
      I completely agree that this does not make my "Top 10 List"  of things to be concerned about.   I also take comfort in the idea that I am not in the "top one million" WiFi sites anyone would want to crack.  But, I cannot help but notice the dramatic trend toward moving nearly everything to an encrypted connection.  Why send a password "in the clear" when it can easily be encrypted?  The software is already loaded on the Orbi.  All it takes is a simple redirection from http to https like all web sites are doing now.
      The other thing, of course, is if Netgear encrypted the Orbi web site, people would quit posting questions wondering about it.
    • prodport's avatar
      prodport
      Initiate
      Hi Jim,
      Good question and I can see the confusion.  The simple answer is your data is not encrypted between your router and connecting to the Orbi web page. This means someone could see your login credentials.  This doesn't mean anyone can view your credentails.  Folks need to know how to peak into this data.  But come January, you'll see more browsers discourage this type of login for security reasons.
      I think the simplest visual representation I've seen is from Distilled.  This is a slideshare deck but you don't need to read it all. Start at slide 13 and you can go through to slide 18.
      In my mind, the lack of HTTPS is shocking these days especially when the hardware is so critical to our web security.  And it's a lot easier to get certificates these days.
      This issue prevents me from recommending the product to others. And I'm sure many enterprise security people who have to deal with executive hardware installations would discourage for this reason.
      My guess is the Orbi app makes a secure connection, but I don't use it for other reasons.
        Retired_Member
        Thanks
        I always thought the Orbi web(?) webpage actually resides on the router, there is no external passage.
        prodport wrote:
        Hi Jim,
  • FURRYe38's avatar
    Any problems from using HTTP on the LAN side would only be seen on the LAN side. When remoting in from the WAN side, HTTPS is used. LAN side connection to the routers weg page would not be seen of the WAN side. Thus again, not a major or critical issue to use HTTP for router web page use.
      Retired_Member
      Huh...??
      who logs in to their Orbi remotely?
      • michaelkenward's avatar
        michaelkenward
        Retired_Member wrote:
        Huh...??
        Strange question.
        Anyone who needs remote access.
    • CrimpOn's avatar
      CrimpOn
      FURRYe38 wrote:
      Its the local LAN side thats doesn't offier https that users are asking about:
      Au contrair, mon ami.  The LAN side DOES support https.  Just type it in (https://<ip of orbi>).  And, when the web browser says, "WARNING - INSECURE - GO  BACK, GO BACK", click on the "Advanced" option (or similar) and go to the web page anyway.
