Superdave132's avatar
Superdave132
Wi-fi channels performance
After installing firmware 2.5.1.32, I chose channel 11 but when I use a bandwidth monitor it shows me on channel 11 but the channel graph shows me on 9 with a frequency footprint from channel 5 to 13, whats happening? Its not causing any issues, but I hope I'm not causing any interference on other channels.
  • Thats now those apps display wifi signal is all. Has nothing to do with Orbi.
  • FURRYe38's avatar
    What app are you looking at?
    What does your Advanced Tab on the RBRs web page look like?
    It should appear as 11(P)+#(S) # being maybe 7 or 9
    • Superdave132's avatar
      Superdave132
      I have wi-fi monitor and the Wireless settings in advanced settings tab showing 11(p) 7 (s)
      Superdave132
      Wifiman test results show the same thing.
  • FURRYe38's avatar
