ECecil
Oct 04, 2018Aspirant
Wi Fi dropping
Installed this system yesterday - connected devises constantly losing wi fi connection, wi fi calling drops calls.... especially when walking around the house. We have two satellites.
- Vendicator1Aspirant
Can you provide some details about your home and how you are connecting your orbis, ( wifi back haul or wired)?
- ECecilAspirant
The Modem is hardwired. The Satellites are connected via WiFi, all lights = blue.
Suggestions?
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
- Blanca_ONETGEAR Employee Retired
Hi ECecil,
Welcome to NETGEAR Community!
There is a new firmware released for RBK50. Kindly update the firmware to 2.2.1.210.
https://kb.netgear.com/000060273/RBR50-RBS50-Firmware-Version-2-2-1-210
Blanca
Community Team
