iancooke101's avatar
iancooke101
Initiate
Dec 31, 2016
Wi fi drops
Hi, pretty new to this so hoping you can help. I've installed the Orbi and all appears to be fine except the wifi connection from the Satellite is ridiculously intermittent. Quite literally will switch from download speeds of 50mbps to 5 to 25 to dropping off completely to going back up to 45. Is there any way I can do something to create a more stable connection? My son is going mad as every few minutes his Xbox live drops completely so he's in and out of games, losing his connection. Really frustrating. Thanks in advance,
Ian C
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Iancooke101
    You can try to adjust the wireless channel in the wireless settings you may also want to try and move the satellite a little closer to where the main router is.
    DarrenM
    • iancooke101's avatar
      iancooke101
      Initiate
      Thanks for your reply. Logistics of the house mean they are as close as they can be. Light comes on blue so I'm assuming the proximity between router and satellite is ok. In terms of adjusting wireless channels do you mean set the Orbi to channel 1,6 or 11 via admin settings and / or on my BT broadband router which in turn connects via Ethernet to the Orbi router? Not sure if I need to change channel settings on both? Thanks.
      • DarrenM's avatar
        DarrenM
        Hello iancooke101
        you would just need to adjust the channel on the orbi.
        DarrenM
