jarmot
Aug 17, 2019Follower
WiFi connection often lost RBR/RBS20_AP mode
Hi,
Problems - any advices?
Symptoms:
- drops wifi now and then - especially to iOS-devices
-”wrong password to network” -message —> right password does not help
-restart orbit helps
System, AP mode:
1000/500 fiber —> Ubiquite EdgeRouter Lite (os 2.0.6) —> Dlink DGS-1008D switch —>
Orbi RBR20 , FW 2.3.5.26
Orbi RBS20, FW 2.3.5.26 via ethernet
I have a feeling that this started when the FW was updated to this verision.
Thank you for your help & ideas.
Jarmo
- ekhalilMasterThere is an issue with wired backhaul in the latest software.
Please follow the steps in this post as a workaround: https://community.netgear.com/t5/Orbi/Wired-Backhaul-in-recent-firmware-releases/m-p/1783871#M67538 - FURRYe38Guru - Experienced User
I would try a factory reset and setup from scratch if FW was updated recently...
Please test the Orbi system directly connected to the ISP Modme with out the DGS-1008D switch in the mix. There are known issues with switches that have Green Ethernet features. Not compatible with Orbi.
jarmot wrote:Hi,
Symptoms:
System, AP mode:
Jarmo
