Kkendra
Jun 29, 2021Tutor
wifi connections in air traffic flight path
Has anyone experience network interruptions (network drops oftern) when airplance fly over? I am thinking the broadcast something to the tower at the airport and it interrupts my network, same frequency as the internet (Orbi).
IF you had not set that up initially, then you may need to factory reset the RBR and walk thru the setup wizard with a PC and web browser. This time write down all important information for safe keeping later on.
- tucsonticoVirtuoso
WiFi can be interuppted by many Radio Frequncy (RF) signals. Any RF transmission doesn't stay completely in it's designated frequency, there is always "spillover" into other bands. It is VERY possible the dropped signals you are experiencing are due to air traffic radars, BUT the drop outs could be simply co-channel interfernece from a neighbor's WiFi.
Try changing channels, especially on the 2.4 mHz band. Channels 1, 6 or 11 are best to try. However, most modern routers (ORBI included) will automatically switch channels to avoid constant interfernce.
Here's an article that explains why WiFi works the way it does: 802.eleventy what? A deep dive into why Wi-Fi kind of sucks | Ars Technica
Good Luck!
- KkendraTutor
Do I do that in the Orbi app?
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- KkendraTutor
Well I havent figured out where I can find the settings. All I see is device manager, security, internet speed. etc. Even under WIFI settings no advance setting tab. also under router settings rbr5o no options to change configurations. this is the orbi netgear app.
Do I need to access the website itself. Netgear.com?
Do make any kind of changes you need to use a PC and web browser and log into the RBRs web page at orbilogin.com or 192.168.1.1
