wesseljc's avatar
wesseljc
WIFI dropping, hard wired PC still works - RBR50
Route will drop WIFI and satellites frequently - My PC attached via network cable has internet access - but both Orbi satellites and all wifi attached devices are dropped.  this is happening 2-3 times in the evenings.  I will reset the router (power on-off) and get wifei back in <4 min.
Firmware version is 2.1.4.16
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
  • De-activated the settings as recommended.  did no help as I lost connectivity again and had to restart router.
    • FURRYe38's avatar
      • sjthespian's avatar
        sjthespian
        Guide
        I'm in the same boat, I have random wifi drops and slow performnace with my Orbi RBR50 (with two satellites). I run the Orbi in AP mode since I already have a firewall and router.  In fact, I have a farily extensive home network with an assortment of systems and IoT devices. Everything is fine without the Orbi, whether I pull out my Netgear Nighthawk or my old Cisco AP. The Orbi is great after a power-cycle, but performance slowly degrades over time until it becomes almost unsuable from *any* device connected to the wifi -- MacBook Pro, assorted iPhones or android tablets or even simple embedded devcies that are only sending a small HTTP request every 15 seconds.
        The Orbi of course shows solid connections to both satellites.
        And I have tried all of the suggestions from this forum post and others, all to no avail (changing 2.4GHz channels, disabling assorted settings, etc). It also affects all devcies using the Orib, whether 2.4 or 5 GHz. And it isn't anything as simple as a saturated network connection, the uplink at the moment is runnign at only 100Kb at the moment, while my iPhone can't even downlaod a simple web page on the WiFi. The only thing that is consistent is that it works after a reboot and degrades over time.
        I even took a walk around the house with a couple of Android wifi scanning apps and signal strengh is great everywhere.
        If only this thing supported syslog (or any other sort of logging) I could get it to log to my server and see if there were any errors or other intersting messages.
        My Setup (DSL -> pfSense firewall -> Cisco 3750 -> RBR50)
