Jeannet's avatar
Jeannet
Tutor
Oct 19, 2021
Wifi dropping out - Do I need to update the software - How?
Dear All,
I bought an Orbi AC3000 Tri-band WiFi Add-on Satellite(RBS50) in July '17, so it must by now be an old model. It has a network extender and one satellite. The extender is connected via wifi to a Virgin Media router.
The wifi randomly drops out and re-establishes itself after a while. When I restart the router and synch the extender and satellite the wifi comes back, but it's tiresome to have to keep doing this several times a week or more.
There are also wifi black spots in my house.
I have requested a new router from Virgin, which has just been installed, but it doesn't make any difference.
Would it help with the wifi dropping out if I updated software in the extender? I don't know if that is something I should do and if so how.
Would it help with the black spots if I bought a second satellite?
I would be grateful for any suggestions, but be gentle in your replies - expect zero techie knowledge!
Many thanks and best,
Jeannet :-)
  • CrimpOn's avatar
    CrimpOn
    It would help if you could double check a couple of things:
    • The exact model numbers of the devices, from the product lable on the bottom.
      One is likely to be "RBR50" (the "R" is for "Router") and
      The other is likely to be "RBS50" (the "S" is for "Satellite")
    • How the RBR50 is connected to the Virgin Media router.
      Orbi routers can be connected in only one way: using an ethernet cable from the WAN (yellow) jack on the router to the Virgin Media unit.
    If there are areas in the house with poor WiFi coverage, another satellite is one solution.
    • Jeannet's avatar
      Jeannet
      Tutor
      Hi CrimpOn,
      Thanks for your suggestions. I checked and I, indeed, have an RBR50 and an RBS50. You are absolutely right, that the RBR is connected to the Virgin router with an ethernet cable. I'd forgotten that because I've been synching it with an WPS button, which I thought was to do with Wifi. The RBS50 is connected to the RBR50 via Wifi, again synched using a WPS button.
      I have spoken with Virgin who are sending out an engineer to see what's going on, on Monday. I'll let you all know the diagnosis and hopefully the solution!
      Thanks again for your support!
      Jeannet  :-)
      • CrimpOn's avatar
        CrimpOn
        It is also helpful to know the exact model of Virgin Media device.  Many (most?) of them are combination modem/router/WiFi devices.
        Are there any devices connected directly to the Virgin box or to the Orbi with ethernet?
        If so, what happens to them when the Orbi WiFi signal disappears?
        How do you administer this Orbi?
        • Not at all.  Just plugged it in and are using the WiFi credentials printed on the product label (bottom)
        • Using the Orbi 'app'
        • Using the Orbi web interface (http://orbilogin.net)
        One last question: the Orbi RBR50 is in "router" mode, correct?  (not Access Point (AP) mode)
        This issue may be very difficult to resolve, because it is not supposed to happen.
        As long as the Orbi router has power, it should broadcast WiFi and devices should be able to connect. If the Virgin Media signal disappears, the Orbi should continue to function.  (Without Internet, of course, but still blasting away the WiFi signal and letting devices connect.)
        In addition to addressing the issue, at some point it may be useful to examine some other aspects of your setup.
        (This is a lot like going to a mechanic because "my car stalls on the on-ramp".  At some point, other issues will come up: do the tires have enough tread? Has the oil been changed recently? What about the air filter? Do the brake lights work? etc. etc. Those are valid questions, but probably not pertinent to the problem.)
        Most users would elect to turn off WiFi from the Virgin Media box so that the Orbi will have one fewer WiFi signal to compete with.  There are also specific situations which can be affected if the Orbi is in router mode and the Virgin box is also a router.
        https://kb.netgear.com/30186/What-is-Double-NAT
        Those are questions that do not appear to be relevant to the Orbi WiFi signal disappearing (and then reappearing).
  • FURRYe38's avatar
    If this is a RBS50, then the RBS50 is not compatible with your ISP modem/router. RBS50 only connect to Orbi AC wifi systems.
    There is a RBS50Y thats a outdoor satellite that if the extender mode FW is loaded can connect to non Orbi wifi systesm.
    Jeannet wrote:
    Dear All,
    Jeannet :-)
    • Jeannet's avatar
      Jeannet
      Tutor
      Sorry, Furrye38, I was unclear in my posting.
      I have a Virgin router, an ORBI extender RBR50, which is connected to the Virgin router with an ethernet cable, and to which the Orbi sattelite is connected via Wifi, synched using a WPS button.
      I have spoken with Virgin who are sending out an engineer to see what's going on. I'll let you all know the diagnosis and hopefully the solution!
      Jeannet  :-)
      • FURRYe38's avatar
        Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
        I would try option #2, if not then Option #3.
        Jeannet  :-)
